I was preparing to change my front wheel bearings as there seemed to be some play and I found that it was the thread in the fork which is the problem. I was thinking about using a helicoil repair. The axle thread is in good order. Any thoughts on this?
Thanks in advance.
helicoils are stonger than the alloy, so yes, It should work fine.
Cheers Drewpy!
