Posted May 2, 20159 yr Hi guys complete rebuild fzr 600 speedo/revs seem to be slow. Taking it easy running her in but feels faster then she reads can rev the t*ts slipping clutch was wondering if a common problem anywhere? New cable and worm approx 40k on the clocks engine obviously still tight as f**k
May 7, 20159 yr Moderator not sure what the question is. I'm not young so can't read this "new english" thats written today. There's no punctuation If you can rephrase it, maybe we can understand the issue!
May 8, 20159 yr If I read this right your saying that the speed your doing is faster than indicated on the dials, is that correct? If that is right then the best thing you can do is get a mate to drive infront of you at 30/40/50/60/70 and see what your clocks say, it's cheaper than going to a Dyno to get it checked. Course all this might be in vain as you were not talking about your speedo and dials at all. Or, it might be that your asking about the Rev counter ? And that is not reading correctly with the perceived engine speed your getting, so what you might be saying is that when you rev the engine it rev's up but the needle on the counter does not move as much as you think it should nor does it match the speed your doing. Is that the question?
