Hi all, new member here had my bike for a couple of months and love it, but I had a small accident which ripped the wiring out of the speedo and rev counter, the speedo part was easy as it was just bulbs, but I can't get the Rev counter to work and for some reason the main head light doesn't work on normal but works fine on full beam, if there is anyone out there that has a ybr 125 2005 and wouldn't mind taking a pic of the Rev counter under the outer casing for me, I would be over the moon, cheers all
Alex
Might be an idea to check to see if the bulb is ok, usually if one works but the other don't it;s a blown bulb, they use the same circuit.
Bulbs are all good, brand new only a few days ago, it's because of the wiring that the head light doesn't work properly... I'm convinced lol
