DT175MX head gasket leaking
Hee  "  brilliant,,,,,,:lol:
And oil on lounge carpet too
Sheared the head off a bolt off in the clutch basket! 15 quid on fine drill bits later went to Brian s Pope stockport and got new bolt
Just rebuilding clutch and noticed there is play on the basket gear and the basket. Will I have to go to grampian again to have the 6 studs that hold the gear to the basket oversized and the basket drilled?  Got a feeling thats where the bottom end knock was coming from.
Regards Simon
Its rivits aint it simon,   some baskets have rubber cush ,  they can be rebuilt, . this slack is usually felt in the clutch lever, [ kinda delay in feel ]
never done a rebuild, but seen a thread on 2stroke forum , [ rd400 basket.]
There are kits available which have bolts to replace the rivets , and a new damper . Not sure but try Mitaka .
Yes see that yambits do the basket kits but for RD's. Is there rubbers in a 175 basket? The knock on mine is a metallic clunk.
yeah there's bound to be some play after all those years, there are rubbers in there, myself I wouldn't bother...cant see why you'd think it's causing a knock just because the rubbers will be a little eroded?
Well put engine back in the frame finished at 2am this morning in the conservatory. Missus says this is not a garage it is a conservatory. I retorted with her lads box of toys has sat in there 6 yrs! Started it 8 am this morn all good but still the knock on rhs casing not there under acceleration or deceleration. Going to buy a basket off evilbay and take it apart and find bolt kit that fits. Many thanks for all your input!
Regards Simon
  • 4 weeks later...
Clutch basket fitted with new heavy duty EBC plates. Got it from USA but it has holes in it
http://i235.photobucket.com/albums/ee14/Simon46/Mobile Uploads/DSC_0322.jpg
Old basket play vid
http://s235.photobucket.com/user/Simon46/media/Mobile Uploads/MOV_0321.mp4.html
