Removing chain on xvs 125
Can I use a. Chain splitter tool on any link in the chain or is the a specific link you are ment to undo
People mention grinding links out but surely you can just use a chain splitter
If you are replacing the chain you can cut off the old one with a hacksaw or bolt cutters . Make sure you get a split link for your new chain and fit it with the closed end facing the direction of travel .
