dt cut out problems pleasr help!!!!
Dont be daft. If that key was bad IT WOULD STOP AND STAY STOPPED.
If all the wiring is good then it has to be carb.
Your going to have to be honest and accurate if were to go further.
What is your idea of 'cleaning carbs'?
I've stripped it jets float valve every thing out and ultra sonic cleaned at my local shop
Ohh yeah mate its on good I've cut a little of the end its sparking good as well I'm stumped!!!
this 2002 DTR is a model with a flat slide carb right?
Yes that's right mate
Do they have accelerator circuits like my tdr250, sticks some extra juice in when you open the throttle hard to stop the engine balking..
