Help needed please
When the ignition is turned on no lights come on anymore and you can't here the power valve,
Also recently it starts fine but smokes a lot ! When revved and the glass to check the engine oil the oil is a red but is frofy
Also from the overflow pipe there is red oil poring out, not sure if it's 2 Stoke oil or engine oil ? But after a couple of seconds black oil comes out and mixes so I'm not sure what oil it is
Can anyone please help me ?
Be seal on 2 stroke pump, filling the gearbox,,, :eusa_shifty: on a ?????????????????
Edit" I see you"ve posted this exact thread on the DT FORUM, so it be a DT 125 ? DTR ?
