Ok I've changed the battery on Yamaha ybr 125 n it still won't run I've checked spark plugs but noticed a red wire coming from ignition towards battery not sure where it goes
57cb8001866bf0b9a33ed0f286505158.jpgef7a7656ae9f68158dc1112ea3a145e6.jpgbaabfe5beba5840cde5793a9b5020e92.jpg
Im taking a guess that the red wire hanging by the negative battery terminal should be connected to the positive terminal on the battery, but it looks like its been ripped/pulled off and may not now be long enough.
Was the bike running before you swapped batteries?
none of those wires are standard and looks like they've bypassed the fuse box!
you need a multimeter and check what's live, and if there are any continuity on the bare wires
Yes kick start n took spark plugs n put back in ht lead n put other end onto the side of the head n then kicked it over
Ok " so its fuel then ,,,whats the carb like,,,and is there fresh fuel in tank,
