Fuel tap replacement
Hi all hoping for a little help/advice
.I have an fzr600 1990 (see gallery) the fuel tap on these bikes are prone to snapping.was wondering if there are any direct replacements of the usual metal type.those of you in the know will be aware the fzr has a long plastic one. Thanks for any forth coming help.
there's over 800 pictures in the general gallery and nothing in your personal one.
I'm not spending 1/2 hour looking for a picture
The taps on these bikes use a black plastic tap that sticks out horizontally about 3 inches (imagine a key fixed to alloy casing) unfortunately this is just under the frame and is usually snapped off when tank is removed.was hoping the more common small alloy type would fit.housing is basically rectangular about 5cm long 43mm between screw holes two filter tubes different lengths (main,reserve).
