Vandame Posted February 24, 2015 Share Posted February 24, 2015 Hello everyone , i have a dragstar 400 for quite few years now ,still i never found a repair manual for it , only the manual for the 650 ,very similar bu yesterday i wanted to start the bike ,the engine turned over like 1/2 or 2/4 of a turn and got stuck with a <clong> noise , my guess is a valve stuck opened perhaps i will have to investigate by opening the valves covers but does anyone knows if the valves are the same size for the 400 and the 650 ??? i'd like to believe that cylinders are the same size, consequently the heads are the same as well , piston bore probably smaller and perhaps crankshaft different as well.So where can i find a manual for the 400 ?? are the valves same size for the 400 and the 650 ?/ Thanks for your help , Claude. Link to comment Share on other sites More sharing options...
Campaman Posted February 25, 2015 Share Posted February 25, 2015 The 400 was produced for the Japanese home market, the frame and everything else is supposed to be the same as the 650, not sure if the actual engine is the same, the 400 weighs a bit less than the 650 which could mean its a different engine as logic says a 650 engine with smaller bore should weigh more. Link to comment Share on other sites More sharing options...
neversaydie Posted February 25, 2015 Share Posted February 25, 2015 Id be inclined to take the spark plugs out and check for hydraulic lockup first Link to comment Share on other sites More sharing options...
Variomatic Posted March 3, 2015 Share Posted March 3, 2015 Id be inclined to take the spark plugs out and check for hydraulic lockup first I agree to check this, but I somehow doubt it. I'm gonna guess a stuck valve. Link to comment Share on other sites More sharing options...
