February 13, 201510 yr Hi peeps. I have a 78 xs250 I restored, from early on, I intended to convert to a 400. I purchased a set of 400e carbs(well I was told they where, or sold as) some time ago, any way, after stripping the motor, and commenced the change over,that seamed to go ok. and now got to the carbs, something is not right, it appears, its either the float cover chamber is wrong or the carbs. on checking the parts book I have,the part No.2A2-14984-01, which didn't look correct, so had to order p/n 2a2-11351-00, with the hole in it.. the float chamber I have looks like the correct, from the Parts book. so can anyone shed any light on this, please check photos. PS hope it all makes sense. thanks graham sorry unable to edit with an arrow.the first , bottom right hole, not the screw hose.
February 13, 201510 yr Moderator I'm off out now so will have a look tomorrow to see if you have the correct bowl
February 13, 201510 yr Author well I've been doing some searching, and discovered that there off a 80/81 xs400, and found bowls to fit, but will these work ok, I wonder. the jets in the carbs are correct for the bike, but not sure of the slides. also found 3 sets of carbs, correct for the bike, at 145. including shipping/postage from the good old US of A, and will have to strip and clean.
February 14, 201510 yr Moderator on my carbs, that hole is blanked so it must be an access hole when they make the carbs, maybe they are used in later specced carbs. mine look just like yours
February 14, 201510 yr Author thanks drew. not sure what to do yet, whether to buy bowls(40 + from usa), and try them, or buy the correct !!! set(near 200, from the usa).
