DT125MX
marccleave
This post is 3266 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
As well as being my daily transport this is also a running project! It has its ups and downs...
When its behaving itself it looks something like this:
CX2YCma.jpg?1
Xxya0II.jpg?1
vx2h0vW.jpg?1
But following a spectacular main bearing failure I'm now in the process of rebuilding the 2A8 engine...
Took a few minutes to remove the engine from the bike and get it on the bench.
Clv9wDJ.jpg?1
J37RUkl.jpg?1
3OAqbSm.jpg?1
Does anyone know where I can source the correct right hand main bearing with the groove in it for the retaining clip??? 6304NX2 I seem to recall...
Google Ty trials.
You will get every single part you need from them.
Rebuilt mine twice with parts from them and have no complaints on price or service.
Any decent bearing supplier should have/get you one
I've already got my local bearing supplier on this and they're looking into it for me, thought I'd ask anyway. :)
Google Ty trials.
Just looked them up, found a few parts I require that I haven't found anywhere else! Cheers!
Right then, after dissassembly... the left hand main bearing does not want to part from the crankshaft. Took it to my friendly engineering shop and got them to remove it.
RtzLAp7.jpg?1
Water keeps getting into my gearbox and I think I've finally found out how! Note, gearbox oil should not be this colour!!! O_o
HeWWw9j.jpg?1
Found how its getting in me thinks... Its going to be a pain to remove, look at those corroded heads!
wmygKih.jpg?1
And check this out... crankshaft oil seal not sitting correctly. Oh dear...
FRSaxx8.jpg?1
Eck. Ive done this in 2014. Pushed impact driver with BRAND NEW BIT Into heads. Worked ok for me.
S.
Good bit of work going on here, since when did yams start using NX bearings [ grooved] Kawasaki had them on gear shafts. on horizontal split casings. cant see how they"d work on vertical split engines,, :eusa_think:
S.
That'll work for the two heads that are still intact. One of them is almost non existent! Eeek!
Who knows! - I'm not Yamaha! ;)
Ta da, picture:
I built my H2 a few times , the grooved bearings had a half clip, it was to stop lateral movement, [ so I was told] that another reason you get missed gears,[false neutrals] if theres wear [ even 1 or 2 mm] on bearings the shafts move away from each other enuff to miss gear selection, couple this together with worn selectors and its rebuild box time,
Anyway the mains were normal bearings held from spinning in the cases by a smear of locktight,,
The new right hand main bearing I was supplied (supplied 6304 not 6304NX2) does not have a groove. I rang up the supplier about said missing groove and after some research they said that all bearings they could/would supply would not have this groove and that I would have to find it elsewhere. Oh well!
Thought only the output shaft bearing had a ring.
Mine dont have one.
Yes you are correct! My mistake!!! :madflame:
Just checked the engine casing. Guess which bearing is still sat in the engine case and guess which bearing I removed (and for some reason) assumed I removed the right hand main bearing.
D'oh!!!
Don't I look like a right plank now. :crazy: :crazy: :crazy:
We learn from our mistakes though, don't we?!
Shows we know our Dt mx's as well.
