February 8, 201511 yr Hi, I have a dt125 98 and recently changed the gearbox oil to find there was petrol in it, in the oil I also found a few small fragments of crankcase sealant. If anyone could help me figure out what's wrong that would be great! Don't want to start stripping the engine down if I don't have to
February 8, 201511 yr Think that's a given about the engine strip, if you have fuel in the oil then you have a leak down into the crankcase, might just be rings and a piston, others on here will know, loads like the DT. It's always best to do an INTRO in the new members section before you ask a "How do I fix my bike" question cos folks are wary of ONE HIT WONDERS who rarely say "Thank you" even bother to reply if you help them out. Just sayin!
February 8, 201511 yr Moderator It's more than likely you need a new crank seal in the right side of the engine but check the bearing for movement first
February 9, 201511 yr Moderator Could be. But if there is sealant in there it could be a leak through the case join. If it was the rh seal you would need a lot of fuel to fill the case to cause the problem. Fuel can creep through smaller gaps. A small leak in the case to case seal would allow fuel residue out when the engine cools. At the same time would not allow oil through........yet.
