DT 125 LC clutch problem 2015
yep you have a big air leak and so it wont start unless theres lots of fuel to go with all that air
is the throttle closing fully...can you hear the click as the slide bottoms out on the throttle adjust screw?
  • Replies 49
  • Views 12.4k
  • You will most likely split the ally. Also you will get swarf down there you cannot remove. I would work on the shaft till it opperates nicely in its hole. That will be the safest bet i think.
  • mcferreira100
    mcferreira100
    oops..my bad.
  • mcferreira100
    mcferreira100
    In my defense I did turn 50 3 days ago..so brain getting bit moldy.
Yes the throttle is closing properly, it looks like i have a small crack right after the carb, could this be the problem?
Sounds like a culprit to me . Try temporarily blocking the cracks with tape or silicone sealer to see if it makes any improvement .
Turns out it wasn't a crack just a seam, spent another 4 hours looking for a leak and cant find anything, reeds look fine not sure what to do next
I have gotten it to the point were it will start up right away with the choke on and only with the choke on, but once it starts i have to turn it of or it will rev too high, if i keep reving it it will run but it wont idle, i have played with the idle screw and still nothing, i have tried the carb needle in 3 different spots and it still wont idle, the jets seem to be clean. Not quite sure what to do
The pilot jet need looked at, as when screwing the air-screw in it should stumble and die. and when screwing out - it should rev up,
this is why it will only run on choke,
No matter where i put the air-screw it still wouldnt idle. Ill take the carb out and look at the pilot screw a bit better, thanks for the help
Unscrew it, you"l need a small/ medium flat screwdriver, andlook at it thru a magnifying glass, see what size, ie 40/45/50, etc,,
Its a 20, looked a little plugged up to me, just blowing it out with some compressed air to see if i can clean it
