thundercat speedo
Just bought a thundercat
Test drive went well everything worked as it should
but on the drive home I stopped to fuel Up and Down the road I noticed the speedo wasn't moveing any advice on what is the issue or what to check and repair would be great .
Certain the Thundercat has a speedo cable driven from the front wheel. Check to make sure it hasn't come undone where it goes into the drive from the front wheel and at the top where it goes onto the speedo. If it looks connected it could be the inner cable has broken.
Tony
Thanks Tony will check tonight
