March 30, 200619 yr bike was running fine but was time to rering it. bought factory parts, pistion ring,o-rings for the head,cyl.gasket. installed the parts and now exhaust is filled up with antifreeze and oil and antifreeze is mixing in the transmissiom case. any clues? I have have the head and the cyl. pressure tested and they are fine. I have taken apart three times and triple checked o-rings, gasket, and also pulled water pump seal to check the water pump shaft for any abnormal marks are scarring on the shaft. all this is after it has been kicked over several times. pull the spark plug and covered wuth antifreeze. any help would be very nice .
March 31, 200619 yr Sorry mate i cant help you. Sounds like there is some srios problems going on there. Have you compared your new gasgets with the old?? its somehow is leaking into the cylinder plus have you fitted anything like this before?? My advise is get a pro to sort it out. i dont mess with things like that (well not since my MR2 tried tuning it to 400bhp and blew the gearbox)
April 3, 200619 yr Sorry mate i cant help you. Sounds like there is some srios problems going on there. Have you compared your new gasgets with the old?? its somehow is leaking into the cylinder plus have you fitted anything like this before?? My advise is get a pro to sort it out. i dont mess with things like that (well not since my MR2 tried tuning it to 400bhp and blew the gearbox) im surprised it never blew the car cause mr2s dont like much more than about 300 bhp lol
April 4, 200619 yr Admin Im sure Scotts talking about the SW20, 3S-GT Engined MR2 its 245bhp as standard if i remember. I went to look at quite a few mr2 turbos before i got my supra... bloody quick things. A lot of the supras they race run this engine as its a lot lighter. Check out these MR2 vids... ones 800 bhp!!! http://www.youtube.com/results?search=Mr2
April 4, 200619 yr Im sure Scotts talking about the SW20, 3S-GT Engined MR2 its 245bhp as standard if i remember. I went to look at quite a few mr2 turbos before i got my supra... bloody quick things. A lot of the supras they race run this engine as its a lot lighter. Check out these MR2 vids... ones 800 bhp!!! http://www.youtube.com/results?search=Mr2 i never was a lover of the mr2 its just to girly
April 6, 200619 yr im surprised it never blew the car cause mr2s dont like much more than about 300 bhp lol True but i had the rather expensive rebuild ect. rebored / forged pistons/billet steel crank / polished conrods / blitz 850cc injectors / ported / 4 paddle clutch / larger intercooler / apexi ecu/boost controller/ blitz air filter/ exhaust. O did i mention the stage 3 turbo T26b(2 bar) that helped. Might have a pic if your interested. total cost £25k To cut a long story short...Too much hassle not enough enjoyment not to mention the drain on my resources. Now i stick to bikes. More power to weight than a car could ever get and i get bigger buzzes. Although i did enjoy whipping porche 911turbo's (just seeing the owners face thinking this cant be happening to me with my 60k car!) im surprised it never blew the car cause mr2s dont like much more than about 300 bhp lol Mine was obviosly a jap import. rev 3 1996, twin entry turbo. I had to swap my turbo for the old rev 2 one as the ceramic plates in the rev 3 were prone to breaking plus i think the old ones were bigger ct26-ct22b im surprised it never blew the car cause mr2s dont like much more than about 300 bhp lol Your correct mate you cant tune a stock mr2 above 300bhp due to the turbo and intercooler limitations not to mention the long bore stroke. Although iv heard some people tuning the older rev1-2 up to 330bhp due to the larger turbos on those but i dont believe a lot of that shit, I believe it when i see the dyno graph readings!
April 7, 200619 yr why the hell did you quote 3 times lol sorry mate i didnt realize i was only allowed to reply once!!!!! lol
April 7, 200619 yr sorry mate i didnt realize i was only allowed to reply once!!!!! lol ah yeah i forgot if you reply more than once it puts it all in same message
