Dt125 power valve stick
Sorry internet slow here didn't realise it would multi post :/
  • Replies 48
  • Views 17.1k
  • Nope. Take it out clean it and put it back with new o rings. It will be choked with carbon which doesent come off easy. When it does it will have worn your seals. Its not too drastic. Exhaust off.
  • If its doing the cleaning cycle then its not that wrong. That tiddly battery will take all the spare juice if its buggered as there is not much spare when the lights are on. That will make the pv mo
  • I have the Oxford optimser battery charger, cost about £45 and keeps the battery charged right through the winter plus it keeps it from doing the usual thing of over cooking like most cheap chargers d
Power band " that what its called, :yeah: , you see the old race 2 stroke bikes were like this, [ high cut exhaust port] they had to slip clutch outa the corners and off the line ,[ to stay in the power band,]
Yamaha thought " if we could have a Road bike with the big power band, but it needs to be ridable in town,[ bottom end power]
so they made the P,Valve, the gate closes to give bottom end, YPVS.
Sounds like yours aint opening fully,
Yeah that's what I think the problem is , when I was out earlier I found slipping the clutch helped at low speeds , she seemed to have plenty of oooosh if I was able to stay in the band (mainly in a straight line haha)
However I would like to use both ends of the scale bottom end and top end so this problem needs sorted, it's frustrating as there isn't any point in doing anything else until I can check the battery,
The question is when I do check the batt should it read 12v? if it's any lower does this mean it needs recharged? Also the batt still has enough power to start the bike so it can't be that low surely??
A good battery will sit at 12.6 volt roughly, as soon as ignition switched on thers voltage drop. so 12volt aint enuff , that will drop to 11.5v right away,, when recharging it will go up to 13+volts,, whitch is good,,it will settle back to the 12.5 area,
Here . this will do yeh,,, mines is model up about £18.00,
http://www.ebay.co.uk/itm/DIY-DIGITAL-LCD-MULTIMETER-DC-OHM-VOLT-AC-BATTERY-OPERATED-ELECTRIC-METER-13190-/320595309882?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item4aa4f8353a
Fixed
Fair point. But start at number 1. So many times electrical problems cause greif because people try and cherry pick the fixes.
So start with the battery. And the generator output, should be less than 14v or therabouts at 6k rpm
Very helpful pal Il buy it ASAP , don't have a clue about electrics or batteries but I know a little more now so thanks lad. What battery would you recommend? are these AMG Batts worth it !!
Fixed
Haha I thought the issue was in my end
Battery issue seems to make sense, but i hope that's it lol How do you measure generator output?
With the engine running put the meter across the battery.
Then take the revs up to 6 or 7k. Simple. Should stop at 14 and a bit. Dont know the exact number. If there is a problem it will likely hit 20+
Motobatt are good,, :yeah: , u-tube to see how to measure current :princess:
Cheers lads , I have no rev meter on dt125x however 6-7000 revs is 3/4 throttle approx ??
Near enough. So long as the volts hit about 14 quickly and stop your golden.
Rightio :-) not be out today too cold won't stop snowing here in kielder !!!
Slight bit of confusion , how can a 12v batt produce 14v ????
Not the battery the generator in the engine produces the high voltage well over 14v in fact the regulator reduces the voltage down to a manageable level, that's why if you regulator goes pop so do your bulbs and wiring. When the power reaches your battery it is enough to charge the battery and run the lights and stuff, to many addons can overwhelm the regulator, that's why it gets hot and burns out, you should check your bikes maximum voltage output before you add any extras like lights or GPS & mobile phones. Hope that helps?
Try this to give you some idea of what happens when your bike is running, not the same as yours but close enough. http://www.electronicamotos.com.ar/technical-resources/library/known-issues/street_65700.html
Thanks il have a look , I've got no add-ons , in fact I'm missing and rear indicator haha il be ordering that multimeter on Friday !
Yeh " what he means is engine off , when you put meter on battery , it should be 12.5 volts , and after starting it should read 14+ volts.
:eusa_shifty:
Cheers again lads, well this morning I woke up to an almighty crash , looked outside and the wind had blown my bike over!!!! It was up against my back door wall with the stand facing outwards and the guests were so strong it's blown over the stand side smashing with left fairing to bits and bending my gear selector inwards ! F****ng fantastic start to the day.
Had a small amount of engine oil on the floor which I hope was coming out of an overflow pipe??? There has been no more leaks since I stood her back up again and I've fired her up all seems well just no more damage has been done
Needless to say her new home is in the kitchen until this ridiculous weather has settled down, hope everyone else's day started better than mine !
Bugger ,,, :eusa_snooty:
Right the multimeter arrived today! After reading another post about them I set the multimeter to the setting immediately above what I was expecting to get ( so 20v as I was expecting around 12v)
My battery is coming in at 2.93 so I assume that it is pretty much as flat as you can get?? Providing I got the multimeter settings correct???
