Hi All,
a few months back MY XT started clicking/tapping then cut out, now she woint start. I have checked for compression as i have recently had the piston changed (no compression not an upgrade) and there is nothing wrond there. I have a spark but the engine will not start.
Does anybody have any ideas?
Cheers
Ged
Sorry just read that again and it makes less than no sense :eusa_think:
Try again.
I have compression but it will not start.
The Barrel and Piston was changed a few weeks before it died so i know they are fine.
Just before it died it made a tapping/knocking noise, lost all power, then cut out.
best check the valve timing, it may have slipped? when you re-assembled it did you adjust the timing chain tension properly??
if it did slip then the piston may have had a coming together with one of the valves...hence the tapping / rattling ?
I put it in a shop to get done so I assume it was all done correctly. I ran fine for 6 weeks or soo then the tapping started and she died within half a mile
My Suzuki had a similar problem, started to make a ticking noise then a tapping noise then no noise !! Valve stem through the piston, unfortunately sounds like you have a similar problem. Mine was a broken valve spring X2.
