January 8, 201511 yr Hi All, a few months back MY XT started clicking/tapping then cut out, now she woint start. I have checked for compression as i have recently had the piston changed (no compression not an upgrade) and there is nothing wrond there. I have a spark but the engine will not start. Does anybody have any ideas? Cheers Ged
January 8, 201511 yr Moderator trying to decypher that ! no compression...is that what you're saying?
January 8, 201511 yr Author Sorry just read that again and it makes less than no sense Try again. I have compression but it will not start. The Barrel and Piston was changed a few weeks before it died so i know they are fine. Just before it died it made a tapping/knocking noise, lost all power, then cut out.
January 8, 201511 yr Moderator best check the valve timing, it may have slipped? when you re-assembled it did you adjust the timing chain tension properly?? if it did slip then the piston may have had a coming together with one of the valves...hence the tapping / rattling ?
January 8, 201511 yr Author I put it in a shop to get done so I assume it was all done correctly. I ran fine for 6 weeks or soo then the tapping started and she died within half a mile
January 8, 201511 yr Moderator well to me it sounds like something mechanical and it's my guess that's piston and valve,
January 9, 201511 yr Author Cheers, I will have a check of the valves. well more accuratly, the bloke in the shop will
January 9, 201511 yr My Suzuki had a similar problem, started to make a ticking noise then a tapping noise then no noise !! Valve stem through the piston, unfortunately sounds like you have a similar problem. Mine was a broken valve spring X2.
January 9, 201511 yr Author Cheers Slice, i am going to look at it this weekend and let you know what it is.
