Suspension settings
Walt57
This post is 3617 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Look in the manual, it;s all there. Or if you don't have a manual, which you should have as a bare minimum, then try this, http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CC4QFjAB&url=http%3A%2F%2Fyamahaclub.com%2Fforums%2Ftopic%2F27141-fazer-fzs600-suspension%2F&ei=482eVIG5FdHe7AbRpYDwDg&usg=AFQjCNEH3_swc--GhTAgCPkhIXhnLzihaA&bvm=bv.82001339,d.ZGU&cad=rja
This is a different year to yours but they are more or less the same for suspension setup.
Be nice if you did an intro in new members section when you get a moment (hint).
Hi there, You ask a suspension Question ,and a guy called" Pre-load " answers eh,, :spin2:
Anyway, 36psi front &42psi rear is the norm for modern rubber,, :welcome:
