wont start
hi all,
my dt250 only fires for about 2 seconds and cuts out
sometimes back fires when kicked
tries to start
plug is wet
any ideas are welcome
If plug is wet , its getting fuel,, but" how old is the fuel ? and renew spark plug,,,and see what happens
year of bike is 1982
fuel is new so is plug and cap
not had it running for about 18 months
engine been out carb off
frame powder coated
I am thinking it might be reeds had a look at them and there is gaps in them
kicked over with carb off/plug out and can see fuel coming back from the reeds
this is my first project and not really used a forum before hoping to start a collection of dt's
thanks for reply
Reeds are for better midrange power, and blow back,,, should not affect starting,, [ as a piston port engine has no reeds] ,
Back fire is fuel in exhaust igniting, does it run on choke? then die when off choke,
it fires for about 2 secs on choke as if it wants to start
with no choke, throttle needs to be open about a quart still about 2 secs
yes there is a lot of fuel in the exhaust
Take out plug , leave over night, clean plug and try to start without choke,, just to see,, is there a good spark,,
yes there is a good spark
it started and revved twice and then cut out
could it have anything to do with the electrics as I have only put in together temporary
, Am shure its carburettor probs here, :eusa_think: , The pilot jet must be choked,, is there an air filter on bike,,?
yes there is a air filter but not had the rubber boot joint on so back of carb is open
it has a new plug and cap with the new plug this is when it revved twice and died
Aha" do you not have the rubber connector, ? if you don't, and want to run it, tape off 3/4 of the carb orifice , with gaffer tape [ super tape] not thin stuff or it will suck it in,,,she should run,,
right all is put back correctly
left to stand over crimo
tried last night to start again
started for 2 secs and cut out
have noticed that the air screw on carb is all the way in ???
thanks
will try
would the idle screw have anything to do with it
