wont start
gght
This post is 3610 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
If plug is wet , its getting fuel,, but" how old is the fuel ? and renew spark plug,,,and see what happens
Link to comment
Share on other sites
year of bike is 1982
fuel is new so is plug and cap
not had it running for about 18 months
engine been out carb off
frame powder coated
I am thinking it might be reeds had a look at them and there is gaps in them
kicked over with carb off/plug out and can see fuel coming back from the reeds
this is my first project and not really used a forum before hoping to start a collection of dt's
thanks for reply
Link to comment
Reeds are for better midrange power, and blow back,,, should not affect starting,, [ as a piston port engine has no reeds] ,
Back fire is fuel in exhaust igniting, does it run on choke? then die when off choke,
Link to comment
Take out plug , leave over night, clean plug and try to start without choke,, just to see,, is there a good spark,,
Link to comment
, Am shure its carburettor probs here, :eusa_think: , The pilot jet must be choked,, is there an air filter on bike,,?
Link to comment
yes there is a air filter but not had the rubber boot joint on so back of carb is open
Aha" do you not have the rubber connector, ? if you don't, and want to run it, tape off 3/4 of the carb orifice , with gaffer tape [ super tape] not thin stuff or it will suck it in,,,she should run,,
Link to comment
  • Recently Browsing
