December 14, 201411 yr I'm having a little issue at the minute with my clutch on my yamaha rxs100. Recently fitted a new clutch it felt a bit damp but it was working. Last night on way home from work it started sticking and becoming unresponsive I was sat in traffic lights in 1st gear and bike wouldn't move off.I pumped the clutch a little bit then it would go. Does anyone know what it could be before I start taking it apart. Thank you in advance help would be much appreciated
December 14, 201411 yr Moderator could be water in the cable, freezing in this cold weather and jamming the movement ?
December 15, 201411 yr So what you mean is " its not engaging" ? look down at the arm when pulling lever, see if movement,,,or stuck as Airhead says,,
December 15, 201411 yr Author Thanks you too, we took it apart last night and remapped the cable seems to be working for now am starting to worry it could be my clutch plates apart from the cable having a kink ever think looked good in the crank case, could bad mapping of cable hold my clutch in so I couldn't set off, my mate thinks the cable isn't the right one it was a small nipple wen the holder in the crank case looks like it should be a dubble ended one, I ordered the cable from wemoto as well Who knows pfffff
December 26, 201411 yr Always oil new cables before fitting them , a drop of engine oil is best . And yes , a badly routed or ill fitting cable can severely affect your clutch or throttle to the point of being dangerous . Some small bikes have a cable for retracting the sidestand attached to the clutch cable , not sure about the mighty RXS but check it out . A manual is best .
