Blew the lights on the YB 100 by over revving?!
Went for a test ride after tightening a few bits up, seemed ok, but I haven't got used to the backwards gears yet.
Over revved the bike and heard a pop. Lost dipped beam. Switched to high beam to ride home, but shortly after lost this too.
Then the back light died.
Can I assume these basic bikes don't have a regulator on the lighting circuit?
And why did the lights not all die at once?!
Quite keen to get this fixed for Xmas as it's a present... But work is pretty mental ATM.
Any help much appreciated.
Ta in advance!!
check the battery didnt boil dry Ed . I think they used a resistor for something, perhaps they dropped any excess voltage by this crude method. I have a wiring diag and parts manual if you PM me we'll arrange for you to also have them ;)
Cheers Paul
Having thawed out i thought the same re battery
I'm gonna have a look tomorrow evening after work
PM sent!
Cheers
I think they have a proper regulator. That would be the pop.
the YB100 (dependant on modal year) had a resistor (hidden behind the number plate) to check if you have one look for a yellow wire with a black trace disappearing into the number plate mount..
if present they never normally gave problems but if the earth (via the rear mudguard) failed you could pop bulbs !
are you sure the head light blew first ?? it is possible the rear light blew first and sent 2 much to the headlight and switching to 'dip' just then blew the dip filiment
Check the wiring harness by the head stock if the outer casing is cracked there is a chance that the white wire from the rectifier is shorting out (this problem popped bulbs also and boiled the battery)
Check the connections to the rectifier (white & red wires)
Check the white wire connection from the mag (under the L/H side panel) .... (this may be a yellow wire or yellow/black trace ... depends on the year)
  • 3 weeks later...
Thanks for the replies, truth be told I haven't had time to have a look yet, due to Christmas, but there's some great pointers here do be getting on with!! Cheers
