1978 DT175MX Ignition
mcferreira100
This post is 3627 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Can someone give me some insight with this ignition? This 175 has the European ignition which I`m not familiar with. I`m used to just on/off but this has 3 on switches. Can`t read the decal so can`t see what setting should do what. I see the first one switches on the neutral and oil light..second switches as first but also the front park light (which my other 175`s also don`t have)..third setting I see park light stays on. With all this the brake light is coming on on first setting..then brake and tail light on second..and only tail light on third. So something screwy at the back as when I apply brake nothing happens.
Thanks Paul..so I gather u guys run them posn 3 all the time.
Weird..got bad connection somewhere. Brake light worked for awhile..now it just stays on all the time when switching on.
