December 4, 201411 yr Can someone give me some insight with this ignition? This 175 has the European ignition which I`m not familiar with. I`m used to just on/off but this has 3 on switches. Can`t read the decal so can`t see what setting should do what. I see the first one switches on the neutral and oil light..second switches as first but also the front park light (which my other 175`s also don`t have)..third setting I see park light stays on. With all this the brake light is coming on on first setting..then brake and tail light on second..and only tail light on third. So something screwy at the back as when I apply brake nothing happens.
December 4, 201411 yr Moderator posn 1 = OFF pos 2 = Engine run posn 3 = Engine run with lights posn 4 = Parking lights
December 4, 201411 yr Moderator It's not a legal obligation to run with lights here but all new bikes and cars have lights on all of the time, so no is the answer unless its dark
December 6, 201411 yr Author Weird..got bad connection somewhere. Brake light worked for awhile..now it just stays on all the time when switching on.
December 6, 201411 yr Moderator pehaps the switch has stuck you'll have to unplug them one at a time to find if it's the front or back maybe even the back brake adjuster nut needs moving a little?
