Hi, my name is Andrew and I live in NSW Aystralia. Bikes I've owned were, 76 kawasaki Z900 and honda xl250. Presently trying to get a yamaha dt175 running. Cheers
Hi mallet " :jossun: the Zed is a heavy beast , hows the DT coming on,,?
Hi Blackhat,
yes, the zed was heavy, it tried to kill me with a tank slapper when i first got it. Put a steering damper on it and everything was sweet.
DT progress: going to drain oil from transmission and fill with recommended oil. Then try and get the clutch to release as suggested in garage forum, if that doesn't work will pull it apart. Are you familiar with pulling these clutches apart?
Cheers.
Hi Andrew, Welcome to the YOC. :wavey:
Yes " DT"s are simple engineering,, when you take the plates off , hang them on summat :icon_wink: [ in order they come off] , and install them in the correct order,
Hi and welcome!
Greetings
:welcome:
