March 22, 200619 yr can it be done, is there the pysical room, would it be stable enough after before I go out and buy an engine
December 30, 200619 yr can it be done, is there the pysical room, would it be stable enough after before I go out and buy an engine IT CAN BE DONE. REQUIRES TIG AN OR MIG WELDER. DIE GRINDER WITH CUTTING BLADE. NEED TO CHANGE REAR WHEEL SPROCKET TO MATCH PITCH AS USED BY DT400'S.
