Bought the bike towards the end of the riding season this year for 750. Had 6000 or so miles on it (odometer was not on the bike had broken off) rode about 1000 miles and now its time to fix it up and do some modifications.
List of mods and work for the winter:
Fork seals
Oil change
Fix leak on bottom of pan
new valve cover gasket
clean everything
french rear tail light and relocate license plate
paint fenders, tank, wheels gloss black
paint motor wrinkle black
powdercoating all chrome, aluminum and some other parts bronze
black clubman bars
bar end mirrors
black and bronze grips
wrap exhaust
digital speedo
new turn signals
led pods for headlights
will post progress as i go. not many people modify these bikes so feel free to ask questions. also this is my first bike so i will be asking questions as a go as well. here is the bike before i tore it down.
Not many Radian owners on here, but a lot of componenets shared with the FZ/FJ/XJ models of the same era
I think they're cracking little bikes, nippy as chuff once above 4500rpm, top 120mph with ease. With decent rubber on, good handling too
See someones already swapped out the rectangular headlamp
Points to watch - keep the caplipers/pistons clean, can seize if ridden in bad weather often - front fender fragile at the edge where the spreader plate abuts the profile change - vacuum operated fuel tap reliability iffy - clutch cut out switch can bend and stick
welcome, well done and good luck with your project, nice photographs :spin2:
unlike yours mine is a monoshock arrangement.
if you find a good source of yam parts, that is old parts, could you let me know please?
Tried all the obvious places for this:-
FJ600 rear suspension (relay) bush part no 90386 - 18135,
it's for an XJ600 but the description seems to be FJ600, same part, nylon bush.
number 8 on the diagram
thought about swapping to mono shock but decided to wait for now. thanks for the tips! never ride it iffy weather heard that the lines can go bad though? havent had any issues with it yet looks like the oil level sending unit on the pan is leaking so ill be looking in to that. as far as oem parts, there pretty tough to come by. ebay has a lot of salvage parts also found that bikebandit.com offers diagrams and oem parts might be your best bet for new stuff.
I do love this bike so far topped it out once racing a new cbr500 and walked it like it was standing still, not bad for a 25 year old bike! also took it to the drag strip and ran a 13.3 with very little launch and no burn out. didnt want to get a streetbike because everyone has them and i like to be different.
http://www.ebay.com/itm/Yamaha-90386-18028-00-90386-18028-00-BUSH-SPECL-NYLON-/181508095199?pt=Boat_Parts_Accessories_Gear&hash=item2a42b9bcdf&vxp=mtrfound this on ebay
  • 3 weeks later...
little update, everything is taken apart down to the frame and motor. sent out the parts for powdercoat and should have them back by friday. next step is ordering fork seals and oil, valve cover gasket. scored some free black paint and bought more primer and gloss black rattle can to freshen up the frame and paint all the bolts. need to pick up a can of wrinkle black for the motor yet and prep the rims and a couple other small parts. once everything is painted i will start assembly
wont be able to ride till spring so im not in a huge rush only thing that will hold me back is money since im still in school. once we get snow i should be set
every one like pictures
I take it you like Black :thumb:
Henry Ford country Blackhat, any colour you like as long as it's black :biglaugha: Looking nice mate.
haha yea i went with black because i did not want to paint the frame and it contrasts the gold/bronze im going with as well
  • 1 month later...
Well it's been a while since I posted, after a fall out with my powdercoater, long story, I sent the parts some where else and got them back Thursday. Worked on the bike all day today and got it all mocked up just need to torque everything down 20150122_101555.jpg
Finally finished everything up just need to fix wiring and adjust the clutch and rear brakes but I took it around the block and rides great here's the finished product Camera%20HDR%20Studio%20-%20142213051881 Camera%20HDR%20Studio%20-%20142213061606 20150124_134416.jpg 20150124_134439.jpg 20150124_134509.jpg 20150124_134520.jpg 20150124_134530.jpg
