Just fitted my rev counter drive assy in gearbox(was missing) and cable spins ok but my ebay purchased rev counter wont work. drive cable turns but no needle action. How do I open it?
regards
Simon
Aha it turns out the backlight illumination light tube is floating around in the clock jamming things. keyhole surgery through hole required!
think tube was glued to clock base originally but bulb and holder is holding it steady. Hooray have working Rev counter. :hyper:
That was about the fast's help ,,nope i fixed it,,I have seen here. :headbang:
Good you got it sorted old clocks not fun to try and open and reclose,it's just the band ring around the face that holds em together,easy to pry open not so easy to re fit nicely.
