YB100 IDLE SCREW NOT WORKING
webber1992
This post is 3602 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Bought myself a yb 100 as a project it runs lovely engine is sweet, cleaned the carb fitted a new plug and cap also cleaned the air filter. the only isue I have is that the idle screw seems to do nothing at all, what are the settings for the carb aswell if anyone can help it would be apreciated. cheers
Have you not wondered why you have'nt had a reply yet?
Does the carb slide move up down when you turn the idle screw ? If I remember the YB100 was a similar setup to the FS1E both using the disc valve engine with the carb on the RH side of the engine. I remember the FS1E had a pin that went through the carb slide and located in the idle screw with a tiny spilt pin, so as you turned the idle screw it raised or lowered the carb slide thus altering the tickover speed. If the slide doesn't move when you turn the idle screw maybe the pin or locating split pin is missing. You can see the pin,spilt pin and idle screw as items 15,16 and 23 as shown here
https://www.yamahamotorcyclespares.co.uk/genuineparts/9010/5/yamaha%20yb100%2082-87/carburetor?uID=0
Hope this helps.
Tony
  • Like 2
