November 2, 201411 yr Just started stripping my 78 DT and need some advice on spare parts. I need swing arm pivot bushing the long steel one, nylon top hat bushings and the chain roller. Also the monoshock pivot pin ( the one with the split pin ). There is a kit for the swing arm available a Yambits, has anyone used it ? Can't see the the pivot pin on Yambits. Do Yamaha still stock these parts ? Andy
November 2, 201411 yr Moderator dont forget the rubber cover on the chain roller, try these guys...they will get them if they are available, I've got spare chain roller and it's rubber cover somewhere if you are stuck...the steel pivot can be made from a bolt if you cannot source one...ask NEO http://www.tytrials.co.uk/trailandtrialsuk/cat_26574-DT175-Parts.html
November 3, 201411 yr Author Thanks Airhead haven't come across Trail and Trials before, will give them a try. Andy
