Moderator Airhead Posted October 30, 2014 Moderator Posted October 30, 2014 If you think it may be starving of fuel, try quickly dabbing the choke on and back off...how does this affect the bogging? 1
jeffhj8 Posted October 30, 2014 Author Posted October 30, 2014 Just went outside and tried this, seems to make it worse/ make it bogg even longer, so too much gas then
Moderator Airhead Posted October 30, 2014 Moderator Posted October 30, 2014 yep, try raising the clip one notch then
jeffhj8 Posted October 30, 2014 Author Posted October 30, 2014 If i do this will it change the idle because it is idling only enough to stay going
Moderator Airhead Posted October 30, 2014 Moderator Posted October 30, 2014 If i do this will it change the idle because it is idling only enough to stay going really idle isnt a problem it's really easy to achieve so dont worry, cant see it having any effect anyhow
jeffhj8 Posted October 30, 2014 Author Posted October 30, 2014 Ok sounds good, what clip are you talking about?
blackhat250 Posted October 30, 2014 Posted October 30, 2014 Clip on the needle , there be 4 grooves in needle , move clip up 1 . that drops needle farther into the needle jet, [ leaner] https://www.youtube.com/watch?v=KXxxJrA5hNY
jeffhj8 Posted October 30, 2014 Author Posted October 30, 2014 ok that makes sence.. i will do that now.. thanks guys for all the help
jeffhj8 Posted October 30, 2014 Author Posted October 30, 2014 I not sure what happened to this thing but the clip on the needle was bent across 2 notches and the lowest part was sitting all the way down on the very bottom notch. and it put some pretty nasty markings and chips in the needle, so i fixed the clip and put it two up from the bottom, so hopefully thius will help.
Moderator Airhead Posted October 30, 2014 Moderator Posted October 30, 2014 I not sure what happened to this thing but the clip on the needle was bent across 2 notches and the lowest part was sitting all the way down on the very bottom notch. and it put some pretty nasty markings and chips in the needle, so i fixed the clip and put it two up from the bottom, so hopefully thius will help. yep, that would make it rich, so hopefully you have your problem solved now
jeffhj8 Posted October 31, 2014 Author Posted October 31, 2014 i hope so too... thank you everyone for the help i really appreciate it. Thanks again, Jeff
jeffhj8 Posted November 4, 2014 Author Posted November 4, 2014 Just an update. Was a pain to get the carb back on, but i got it on after a bit but the barrel in, with the newly adjusted needle. My dumb self put the barrel in backward and it started full throttle scared the crap out of me when it started, but i got it back in the right way. Took it out for a ride and it seems to have almost fixed the problem, still bogging but not as much so ill put the clip up one more notch and see if that fixes the problem. Just another question does anyone know where i can find plastics for my bike? can't seem to find them anywhere.
Moderator Airhead Posted November 4, 2014 Moderator Posted November 4, 2014 Just an update. Was a pain to get the carb back on, but i got it on after a bit but the barrel in, with the newly adjusted needle. My dumb self put the barrel in backward and it started full throttle scared the crap out of me when it started, but i got it back in the right way. Took it out for a ride and it seems to have almost fixed the problem, still bogging but not as much so ill put the clip up one more notch and see if that fixes the problem. Just another question does anyone know where i can find plastics for my bike? can't seem to find them anywhere. Make it leaner at your peril jeff, if you can live with it leave it alone now or risk overheating and holing your piston
jeffhj8 Posted November 4, 2014 Author Posted November 4, 2014 Very true, by moving up one more notch it will be in the center so do you think that would be too lean, or it really depends on the bike and whats going on with it i guess.
blackhat250 Posted November 4, 2014 Posted November 4, 2014 Whats the plug telling you...[ colour ] that's the gauge,,
jeffhj8 Posted November 4, 2014 Author Posted November 4, 2014 Ill post a pic of the plug either tonight or tomorrow if i figure out how... i am kinda new to the whole plug chopping and it looks good to me, so ill let you guys be the judge.
jeffhj8 Posted November 6, 2014 Author Posted November 6, 2014 wont be able to post the picture for a while, silencer broke off the bike and it is way to loud to ride where i live. once i get that fixed i be sure to do a plug chop.
