majestey only on easy start
dsb2014
This post is 3684 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi all hope everybody is ok i have a qiuck question if anybody can help me please ? its my majestey playing up again ive had a fresh complete top end and new plug. the problem i have got is it will only start with easy start and when it does start there no idle what so ever so it cuts out unless litte revs are used. when i took the carb off the manifold is wet with petrol does anybody have any idea what it could be please tia
Pilot jet is probably pluged,give the carb a complet cleaning.
Ok broken english is not going to help,I am no scollar,but you need to be a bit more helpfull to yourself. Slow down and type it out
There are many adjustments on the carb,externaly 2.... 1 the idle and 2 the mix for low throttle -pilot adjustment,we are all trying to help so post a picture of the carb and we can point you in the right direction
