majestey only on easy start
hi all hope everybody is ok i have a qiuck question if anybody can help me please ? its my majestey playing up again ive had a fresh complete top end and new plug. the problem i have got is it will only start with easy start and when it does start there no idle what so ever so it cuts out unless litte revs are used. when i took the carb off the manifold is wet with petrol does anybody have any idea what it could be please tia
Pilot jet is probably pluged,give the carb a complet cleaning.
I've got it to idle now it was. The ballast resistor its starts with out a problem. The prob I'm having now is soon as throttle is applied it cuts out
There's. No mixture screw on the side. The only brass screw I ca n see is on top on the manifold. Side the plug. Was I charcoal. Colour ? Thankz for helping me mate
Ok broken english is not going to help,I am no scollar,but you need to be a bit more helpfull to yourself. Slow down and type it out
There are many adjustments on the carb,externaly 2.... 1 the idle and 2 the mix for low throttle -pilot adjustment,we are all trying to help so post a picture of the carb and we can point you in the right direction
