YBR 125 - Tyre recommendations?
This post is 3750 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I'm looking to upgrade the stock tyres on the YBR125 for the winter mostly as I plan on using the bike as often as possible.
Any recommendations?
edit: hmm maybe i should scroll down when entering the forum so I can see *all* sections. I can't seem to be able to move this to the more appropriate section. If a mod can I would be very thankful!
Found what you need then? :)
Still looking. Seems like the well recommended Michelin pilot sporty's are no longer made. Still going to see if I can get a hold of some and if not will likely go for the pilot streets . Still open to getting pointed in a different direction however
