Hi! Need some help with my clutch on ma Yamaha dtr
I have taken cylinder and piston off to rebored but i have noticed my clutch has become very loose, is this due to the barrel being off and no compression? Or have I got issues with clutch as it was fine before I took the barrel off. Thanks
[emoji2]
Hi, It's usual to do an INTRO in the new members section BEFORE you have a "how do I fix my bike?" question. just so we know your not a one hit wonder, we get a lot of those. So if you would be so kind to nip over there and post a hello we would be much obliged. Welcome to the YOC :wavey:
Ok , so am thinking the clutch cable has a bracket attached to the barrel or exhaust mounts . :eusa_think: no way the barrel affects clutch,,
Result :thumb:
