1983 Xj900 fork rebuild
Hi
Trying to find some info on washers req for inside of damper rod on front forks on my bike . I know it's supposed to have 2 wave washers and a flat washer fitted before the seat. Dosent look like my forks has had them fitted so could do with some size info so I can have some made . It's a 31a model by the way
Thanks Alistair
:wavey: Hi Alistair, you'll likely get more responses if you post an introduction in the New Members section. Just let the folks know a little about you and your bike(s). Maaybe you can get part numbers at partzilla and then see if you can cross-reference for sizing. ??
Welcome aboard btw.
