September 25, 201411 yr Hi all I brought a go kart with a ybr 125 engine fitted but doesn't start up as it's not wired and I think parts are missing there is no spark when kick starting. Does anyone no what wire gives the spark of and anyone tell me what to do to get it running thanks Tom
September 25, 201411 yr Ht lead gives the spark, put fuel in it, charge the battery kick it over job done
September 25, 201411 yr Author Hi noise I have no battery with it do I need one if I only use kick start
September 25, 201411 yr Author i have a picture of what i have atm before i stripped it atm where i am just want to buy everything i need to get the engine to start and then i can start bolting bits back on thanks tom
September 25, 201411 yr First Tom you should say high in the new members setion,neat little toy you have. You need the cdi ,voltage regulator,ignition coil and then ignition switch and a good wireing diagram to hook it all up ,,or a harness from a bike to shorten would be the easy way. I assume that you have all the internal electrics,pick up coil and stator. as it has a starter attached might as well hook it up with a battery and I can see in that mess of wireing you have the selonoid. but the placement of the motor will be a problem as your going to get burnt. and where is the seat going to fit?
September 25, 201411 yr Also are you getting full travel on that kick start? As it looks like your going to be hitting the drive shaft before you get a full travel. As DT said you need all that stuff for more reliable starting as if you're in the middle of a race and stall it are you willing to get out try and kick it over, jump back in strap up and race off again?
September 25, 201411 yr Author hi dt502001 i am not sure mate if i have all the electrics thats all that come with it i am new to this stuff and all those wires are very confusing lol i am going to fit a normal seat but try and move the engine over a fraction to allow me to do this if not then ile have to find a solution to fit in. thanks tom
September 25, 201411 yr Author Also are you getting full travel on that kick start? As it looks like your going to be hitting the drive shaft before you get a full travel. As DT said you need all that stuff for more reliable starting as if you're in the middle of a race and stall it are you willing to get out try and kick it over, jump back in strap up and race off again? hi noise i can get full travel on the kick start if i leave the engine in the position it was in but to fit the chair i am going to have to move the engine over and that will cause the kick start to kit the rear wheel. so an electric start would be ideal. i have all the wiring i think for the engine but knowing what wire does what is tricky for me i was hoping to get rid of all the wires and have a basic set up.. thanks tom
September 25, 201411 yr Wires on yams are easy as one plug only goes into one plug (all matched up) so as long as the plugs haven't been cut off that is
September 25, 201411 yr Author ile double check it over tomorow is there any earthing to the kart frame i need to do? what battery do i need? thanks tom
September 25, 201411 yr Moderator I suggest you dowload an owners manual for a YBR125, perhaps that will give info on certain things...the battery spec for example Here http://ymenvom.crestec.nl/new/manuals/U5YJE0.PDF
