Posted September 24, 201411 yr I need some square metal tubing but not sure where to buy it from does anybody know if jewsons or b&q do metal I looked on there website they do building stuff but not sure abut square metal tubing or a flat sheet metal don't need alot to make a wheelie bar
September 24, 201411 yr I think Wicks sell it - it's called box steel. I'm sure there's loads of places online you can get it from.
September 24, 201411 yr Author Yes I believe b&q sell so I got told a min ago ill post some pics when ive made my wheelie bar thanks
September 25, 201411 yr 1st wheelie bar's are never made from square tubing,unless your looking to make 12o clock bar, a drag wheelie bar has to flex so no cheap stuff ,,, cromoly ROUND tube seamless.And even a good 12o clock bar should flex or your going to snap weld points. What type of bar are you wanting to build? EDIT: old leaf springs from a car/truck are cheap and work if you do it right.
September 25, 201411 yr Get the steel from your local Steel Merchant not B&Q etc expensive cheap crap.
