making a 12bar -wheelie bar help
I need some square metal tubing but not sure where to buy it from does anybody know if jewsons or b&q do metal I looked on there website they do building stuff but not sure abut square metal tubing or a flat sheet metal don't need alot to make a wheelie bar
I think Wicks sell it - it's called box steel. I'm sure there's loads of places online you can get it from.
1st wheelie bar's are never made from square tubing,unless your looking to make 12o clock bar, a drag wheelie bar has to flex so no cheap stuff ,,, cromoly ROUND tube seamless.And even a good 12o clock bar should flex or your going to snap weld points.
What type of bar are you wanting to build?
EDIT: old leaf springs from a car/truck are cheap and work if you do it right.
Get the steel from your local Steel Merchant not B&Q etc expensive cheap crap.
