Litos Posted September 18, 2014 Posted September 18, 2014 Hi guys. Im trying to work out how i can use the below switch to turn the engine over, rather than using the usual button. At present, there is no starter button on my scooter, just the kickstart. Any help would be appreciated!
Campaman Posted September 19, 2014 Posted September 19, 2014 Wrong type of switch, you need a push to make switch not a toggle switch.
Moderator drewpy Posted September 19, 2014 Moderator Posted September 19, 2014 if its a Contact No Contact switch it can be used although it would look nicer if you had a push button. plenty of stainless /marine ones out there which will survive being out in the rain.
