Yamaha XT125 x 2009 Speedometer faults
I've read lots of posts on the internet saying that all these bikes have same problem with the original speedo. Is there a fix for it or if not can anybody tell me if there is a decent aftermarket speedo that fits into same bolt holes for this?
Also looking for a wiring diagram for the multi pin plug so i can test the harness to rule out faults there.
Thank you
Exact bolt holes ? trail teck vapor make good one that will fit...And yes the speedos all have a problem change it out is the best way so far .
Thanx I'll look at the trail tech one
I used the trail tech vapour and it was spot on. I paid a garage to fit it and they had to make their own bracket.
