August 8, 201411 yr So I'm ordering some new handle bars and was going to order a new set of grips. Now what am I looking for ? Just 2 standard grips or is there more to it then just standard grips
August 11, 201411 yr Get them as a pair, as the right one will be different in order to fit over the throttle slider. Standard Drag grips comprise the rubber grips, inner chrome-plastic collars and outer chrome-plastic end caps. IIRC, the bars will probably be 22mm diameter (but do check first), so get grips that match the bars.
