Posted August 5, 201410 yr Hi guys, I've suddenly got no headlight nor speedo backlight, though the sidelight works just fine. I've replaced the fuse and installed a new bulb, with no luck. Is there a headlight relay? I've traced the wires back to a relay behind the rh sidepanel, but all the exploded diagrams I can find say that this is the side-stand relay(!) Help!
August 5, 201410 yr Workshop questions should be in the "WORKSHOP" ? Intros in the NEW MEMBERS SECTION (hint).
August 8, 201410 yr Author oops, my bad! new to this site - sorry! Anyhow, prob solved, for those who need to know, it was the starter switch (bizarrely). Cleaned/WD40'd, lights back on! (ps: perhaps one of you admin guys could stick this post in the right place? I'm an old geezer and can't work this interwebby crap out!) Ta!
