hi guys
Hi all,
My name is Ben, I am a total bike noob. So here to get some advice and learn about bikes through the collected wisdom of you guys.
Bought a yamaha xvs dragstar 125 in may as a little workshop project. Turns out the previous owner lied to me regarding its condition and the bike is a non runner.
Zero compression in either cylinder. So tonight I will be starting the strip down and to try locate the problem. Will begin with a few drops of oil into the barrels to rule out worn rings. From there on out its going to be blind leading the blind a bit. Valve timing check is next I guess?
Anyway, looking forward to meeting you all. Your help and guidance will be most appreciated!
Cheers lads and lasses
:wavey: hi Ben! Welcome to the YOC. Start a thread in the workshop (if you haven't already) to let everyone know what the bike's doing and any troubleshooting you've done so far. :)
Hi Sacha, will do. Work is busting my balls today a bit but when I squeeze a brew in ill start a post up.
Thanks for the reply.
:welcome:
:welcome:
welcome ben
Welcome aboard!
Welcome to the YOC Ben, hope you get it sorted ok. :wavey:
