pls can any one help
xtdamo
This post is 3759 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi
If the motor will turn over ie, not seized ( try pushing it a little with the bike in gear and the clutch out) then most common faults that spring to mind are, a flat battery, a poor battery connection, a stuck starter motor, a bad starter motor connection or even a blown fuse depending on how the start system is wired on your bike
Starter motor or CDI fault?
Another one hit wonder
