This post is 3822 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi all been lurking round here for a while now and think it's time to introduce myself.
Located in Cheshire not far from J16 M6.
Had a few Yams started on a M reg Fizzy in 78 then a very brief 6 weeks with a Superdream ( long story) Sold that and bought a DT 175MX T reg.
Sold that and graduated into cars, college etc.
Found my way back into bikes in the 80's and bought a DT again to race in enduro style events in the late 80's down in Coventry. They were on a short circuit but did last for 2 hours.
Put that bike back to standard minus indicators and sold it.
Later I had a TRX850 from new and sold it a couple of years ago after my wife dropped a hint.
That was a really nice bike with carbon Microns and R1 front brakes.
Sold it and bought a Westfield kitcar which I use on track days and spirited drives !
Anyway had the urge to revisit my youth again not to go quite as far back as a Fizzy but to a DT.
So I have found myself after a bit of searching an early white/red and black S reg 13000 miles ,complete with clocks , indicators, original front and rear mudguards and seat strap !
I'm not sure if I will do a concours type restoration or just a really nice job, new paint etc but not to get too hung up about all the really fine concours detail.
Progress so far is :
It starts, runs , has 6 gears, lights work, oil pump works, in fact if the forks were re-chromed and new seals fitted, I think it would pass an MOT, so I'm pleased.
Just received a load of parts from Yambits.
One question which you may be able to help with.
The voltage regulator is located on the LHS below the airbox with a yellow wire coming out of it.
Question . Should the regulator be earthed by a separate wire coming off one of the fixing screws?
Will keep you posted of progress.
BTW. This is another project I did about 12 years ago and still going strong.
http://124sportspider.com/_/Homepage.html
Andy
Great intro Andy, not much left out there fella
wow the Fiat is a stunner, I can see the DTMX is going to be very smart too now
yeah the regulator is mounted on a plastic battery box? so a short black wire with a ring terminal around the mounting screw is the way forward
:welcome:
Thanks for the kind words Airhead.
Yes the Fiat still turns heads.
Will make up a suitable lead and fit.
What is current thinking regarding frame finish - paint or powder coat ?
My thoughts are powder coating is a bit hit and miss quality wise.
Westfields have a lot of problems with shelling off and corrosion setting in.
Andy
Thats what you call an intro,, :eusa_clap: / welcome andy,,, :jossun:
Yeah you could give lessons on INTROS Andy, Welcome to the YOC. :wavey:
Thanks for the comments , the words just kept coming last night.
More progress tonight.
Earth lead fitted from voltage regulator and now the lighting voltage at the headlamp is down from 10 v ac to 6.8 v ac.
Pleased with that.
Andy
:welcome:
:wavey: welcome aboard! Sounds like you'll have her done in no time. :thumb: looking forward to pics.
