Diagnostic by sound
This post is 3787 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
HI so here is a new problem I am having
If I use the choke I can't start the bike, without the choke I have a to quick it a couple of million times before it stars, sometime it works better to push it downhill and start in second gear but even this can take several tries.
Once I get it started and wormed up it seems to idle fine.
When I ride it get this issue, when going uphill it runs out of power it seems, no matter if I give it gas.
I recorded the sound with my phone to see if I get a pointer on where to start looking for a fix
https://dl.dropboxusercontent.com/u/4165737/Bike.wav
Thank you for the help!
sounds like its starving of fuel
either carbs need cleaning or the petcock is partially blocked
youneed to buy for the engine,not the model so check for differences via parts book and you will find they share the same part #
