HI so here is a new problem I am having
If I use the choke I can't start the bike, without the choke I have a to quick it a couple of million times before it stars, sometime it works better to push it downhill and start in second gear but even this can take several tries.
Once I get it started and wormed up it seems to idle fine.
When I ride it get this issue, when going uphill it runs out of power it seems, no matter if I give it gas.
I recorded the sound with my phone to see if I get a pointer on where to start looking for a fix
https://dl.dropboxusercontent.com/u/4165737/Bike.wav
Thank you for the help!
Sounds like your in too high a gear drop the box
Looking on ebay for some time now. One of the problems I am having is that there seems to be a lot for DTs 76 to 81 but not much for 75
youneed to buy for the engine,not the model so check for differences via parts book and you will find they share the same part #
